Adjusting idle?
you can adjust the set screw on your TB ... but if you close the blade, then less air is going to be getting into the intake, your IAC module will have to work more to keep the engine running ... blah blah ... basically your gonna have to get it tuned to get your idle down w/o affecting driveability.
