Late/after market heads on Early blocks
Old 12-12-2005, 01:22 PM
ROCNDAV's Avatar
Default Late/after market heads on Early blocks
I noticed that my AFR heads (and cometic gaskets) have two large squarish cooling passages in both upper corners. The block only has the two front side passages, not the two rear passages. Is this a problem, since the heads do have these passages?
Are these conencted on a newer block? I could drill & tap a hole where these ports are located and run a pipe between these passages if necessary.
I have no fear of going at the block with the die grinder, I've done it twice so far, once for the LS6 valley cover mod and the other for the rear oil passage.
Attached Thumbnails Late/after market heads on Early blocks-dsc03918.jpg   Late/after market heads on Early blocks-dsc03919.jpg   Late/after market heads on Early blocks-dsc03922.jpg   Late/after market heads on Early blocks-dsc03923.jpg   Late/after market heads on Early blocks-dsc03920.jpg
Old 12-15-2005, 02:44 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Dave...
They are there so the same gaskets can be used on both sides of the engine (they are then interchangable)....Do NOT drill the block....you will cause the water to take "shortcuts" and not cool the block and heads correctly.
Tony M.
Old 12-15-2005, 02:56 PM
ROCNDAV's Avatar
That is what I thought when I thought it was just the gasket, but I noticed that the heads also have the passage on both sides (Front and rear).
I just wanted to make sure all was ok.
Old 12-15-2005, 04:49 PM
GuitsBoy's Avatar
Originally Posted by ROCNDAV
That is what I thought when I thought it was just the gasket, but I noticed that the heads also have the passage on both sides (Front and rear). See the fourth picture above.
I think that may be so the heads can be used on either side of the block as well
Old 12-15-2005, 04:54 PM
ROCNDAV's Avatar
Doh! LOL. Damn, I feel so blonde.
