427 summer build?
Old 12-14-2005, 09:32 AM
ls6jimmy's Avatar
Default 427 summer build?
I have LS1 block that I would like to resleeve, but I'm trying to figure out what bore, rod length & crank to use to get to 427? Any help would be appreciated, because I'm trying to round up parts for this summer.
Thanks
Old 12-14-2005, 10:34 AM
Wet 1's Avatar
4.125" bore, 6.125" rods, 4" crank for "normal" 427.
You can also use a 4.060 bore with a 4.125" stroke to reach 427.
Old 12-14-2005, 02:00 PM
Ferocity02's Avatar
Sounds like your in the same boat as me. I am going with a 4.125" stroke and a 4" bore as said. I think it is actually a 427.65, which would be a 428ci, but 427ci sounds so much cooler.
Old 12-14-2005, 03:35 PM
badaSS346's Avatar
Thanks
I think its cheaper to sell the LS1 block and resleeve a LS2. However from what i hear resleeved ls1's are stronger.
Old 12-14-2005, 03:39 PM
98_Formula's Avatar
wouldnt you get more power from using a bigger stroke and smaller bore, as apposed to the first setup?
Old 12-14-2005, 06:03 PM
Ferocity02's Avatar
A longer stroke limits high RPM reliability. I wouldn't feel comfortable spinning a 4.125" crank past 6500rpm unless the motor was 100% solid.
Old 12-14-2005, 09:06 PM
ls6jimmy's Avatar
Thanks for the input
