Lunati 237/242 .050
Lunati 237/242 .050
I decided to with a Lunati 237/242 .050 .595/.595 112 in my 408.I got AFR205s with the valve springs afr supplied,supposly good for .600 Do you all think I should change the springs or can I be ok to run it with the afr springs?
What springs did I put in your car I cant remember the springs I have came with the heads,talked to Tony from AFR yesterday he said just to shim the springs with a .030 shim to get the installed height to 1.780,still thinking now I want the Grand Cup cam
