? about 918 spring and 60+ lift
Old 12-15-2005, 12:57 AM
konryod215's Avatar
Default ? about 918 spring and 60+ lift
Comp 918 Valve Springs (says there good up to 600lift) and the MS3 CAM (237 242 603/609 113) are the springs ok to use with the MS3 Cam?
Old 12-15-2005, 01:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
God i wouldnt... You could, you might see a few thousand DD miles out of them. If you are in the top end RPM's frequently they will be gone before you know it. Best bet is some dual springs man. It will save you the money in the long run...or short run whichever would be your case.
Old 12-15-2005, 01:21 AM
itchygomey98's Avatar
I agree with orangeapeel that it would be a better idea to run a double spring, but I do know that 918's will work past .600 lift - my old setup was .605 with 918's.
Old 12-15-2005, 01:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine is .598 and I have 918's as well. Yes it is do-able, but just for better sleep at night I would do the duals if you can "spring" for them.
