Forged 347 & ETP 225 heads finally running :)
Old 12-17-2005, 01:04 AM
Restricted User
CAT3's Avatar
Default *ADDED VIDEO LINK* Forged 347 & ETP 225 heads finally running :)
Yes. I am so flipping happy now that the car is fired up, running, holding idle, oil pressure and all else. What a weight off my shoulders. Today at 3:55pm, I dry cranked it a few to get oil flowing. I then checked everything one last time, plugged in the coil packs and fuel pump relay, cranked and she started purring, what a beautiful sound
Tomorrow I will change the oil, adjust the pinion angle, and seal up an exhaust leak b/w the drivers manifold and cat conv. Then its off to driving and enjoying it for the w/e before I fly mainland bound Sunday night.
LS6 Block 347, Stock crank, billet caps, ARP Studs, Callies Rods, ARP Rod Bolts, Diamond -2cc Pistons, Morel Lifters, EDC Cam 231/242 .637/.622 @ 114*lsa, Cloyes Hexadjust Timing Set, JWISS Chain, LS6 Oil Pump and Valley Cover, ETP 11* 225 Heads, Trick Flow 8.100" pussrods, Stock Rockers, ASP Underdrive pulley, LS6 Intake (needs to go in a bad way....will Santa bring me a 90/90? ), clearanced stock valve covers (no baffles or oil shield). Stock Water pump, manifolds, cats, y pipe.
Pushing through the ATI 8" 4000stall converter, Rossler Trans braked TH350, stock Driveshaft, and stock POS 10bolt. Nitrous will be hooked back up later. As will the Kooks 1 7/8" headers and Y Pipe.
Still needing to get for finishing touches:
LSX 90mm Intake
Nick Williams 90mm TB
9" Rear 3.90 gears
Bogart Gold RT's
Strange DA Shocks (one o my QA1's needs to be sent in so why not upgrade?)
I should be able to run the rollers around 6/7 Jan. Will attempt to get some pulls with stock exhaust and then next day do the Kooks if I can work it in the schedule. Thank gosh this puppies up and running again, seems like forever.
Charlie
And for the video...
http://video.ls1tech.com/Player.aspx...7-7993E990F425
Old 12-17-2005, 05:30 AM
Viper's Avatar
Congrats, it's been a while for you!
Old 12-17-2005, 06:07 AM
Black02SS's Avatar
Congrats Charlie! I have been following you progress and it does seem like a bit. Best of luck to ya.
Old 12-17-2005, 10:22 AM
69firebird's Avatar
get a sound clip or vid of that thing up, sounds like an awsome setup
Old 12-17-2005, 10:28 AM
Drew778's Avatar
Now go run that BIATCH
Hopefully I can make it down to see it run tomorrow night
Old 12-17-2005, 10:47 AM
7 Second Club
Phil99vette's Avatar
Hey how does that monster sound? Any different?
Phil
Old 12-17-2005, 11:18 AM
LS1 BU's Avatar
Sounds like a stout combo.
Old 12-17-2005, 11:19 AM
35th SS's Avatar
LSX 90mm Intake
9" Rear 3.90 gears
Bogart Gold RT's
Charlie
Congrats brother.hopefully youll bring it to the track tonight since Im workin .wanna hear this beast idle. drink a coke for me.
Old 12-17-2005, 11:58 AM
Restricted User
CAT3's Avatar
Thanks guys. Yes, it has been a long winding, slippery when wet road. For those unknowing, I ordered the shortblock in Dec 04, had it being shipped to Hawaii while in I was still in Afghanistan, and I got it upon my return in April 05. The Shortblock sat on my back Lanai (back patio area for non-hawaiians) waiting various parts, most importantly the ETP 11* heads, which werent even released yet. Now, its in and sounds great. Will try to get some video this morning, while its on the lift and maybe some later today driving around a bit. It does sound slightly more aggressive and seems to have better response than the old TSP 231/237 cam. Idle was almost on from the old cam, only had to adjust the TB Set screw a hair. So happy. Time to go drain oil, adjust pinion angle and get some vid.
Old 12-17-2005, 12:10 PM
Ksett's Avatar
Congratulations on getting your car running. From all of the top of the line mods it sounds like it will be a beast. I was just curious why you opted for the 225's vs. the 215's. I'm trying to determine which ones I will go with myself and they recommended 215's for my stock LS6.
Old 12-17-2005, 12:50 PM
Ed Curtis's Avatar
Cool
Congrats Sir Charles.
An early Christmas gift to yourself huh.
Ed
Old 12-17-2005, 06:31 PM
pdd
pdd's Avatar
congrats
Old 12-17-2005, 08:08 PM
xssive's Avatar
Awesome Charlie! Now I think im the last person with an APE motor thats hasnt been installed. Your success makes me feel alot more confident for sure
Old 12-17-2005, 10:25 PM
Restricted User
CAT3's Avatar
Ksett, 225's are more of compromise for me. I wanted to go with the 245's for more available flow to better suit the cam. Instead I figure Strip/Street duty and 225 it was.
Ed, should finally get some numbers out this beast in Jan. I am going to make a couple lazy test the tune type passes tonight. Jan when I get back from seeing my son and the family, its time to hit the juice again. So far this cam feels "mild", easy cold starts, smooth idle and pulls hard.
xssive, I am still worried, I glance at the oil pressure more then the traffic. I also been monitoring the coolant temp etc. I figure if its going south, I cant stop it and no matter what it will need to be pulled. So, if this one goes, its 402/408 time, maybe larger
Old 12-17-2005, 10:55 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Good luck! Have fun.
Old 12-17-2005, 11:21 PM
Rescue Ranger's Avatar
Man, you guys suck. Driving around in warm weather w/ t-tops off... its freakin' cold here...
Old 12-18-2005, 01:41 AM
Drew778's Avatar
Dude, it gets down into the 60's, burrrrrr
Old 12-18-2005, 07:52 AM
Ed Curtis's Avatar
Cool
That's pretty much what J-Rod said about the "vette's" cam...
... until he drove it ...
Enjoy the holidays with family and let me know how things go once the testing starts. You know where to find me. Under a lot of snow!
Ed
Old 12-18-2005, 07:56 AM
1BDHWK's Avatar
60's!!
Drew, you love rubbing it in!
Congrats Charles!!!! Just getting it to start and run is the greatest feeling. Now for some numbers!
Old 12-18-2005, 09:08 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default snow
Ed
ed, I don't think it would be very hard to cover you up with snow. 1 good noreaster, youd' be gone.
