Most boost youd put on a stock bottom end........
Old 12-20-2005, 06:30 AM
newsouthryder's Avatar
Default Most boost youd put on a stock bottom end........
Whats the biggest psi pulley youd put on a stock bottom end 98 ls1?
Old 12-20-2005, 07:26 AM
777's Avatar
8 psi is the max I would run.
Old 12-20-2005, 08:19 AM
radkon's Avatar
7 to 8 before bottom go boom
Old 12-20-2005, 09:17 AM
conan's Avatar
Don't forget to get a good tune and make sure you have enough fuel.
Old 12-20-2005, 09:33 AM
Dixit's Avatar
Well if you saying just stock BOTTOM end I would say probably 10 or more. I mean if you change the heads with a bigger chamber or even a thicker headgasket you can get the compression down to more reasonable levels and increase the boost. Now granted I dont think the ring landings are going to last with a stock bottom, but Ive seen folks bring their 10.5:1 CR down to about 9.5:1 and get a good 650whp out from the stock bottom end with no problem
Dixit
