Cam bearing replacement
Old 01-08-2006, 05:48 PM
My90Iroc's Avatar
Default Cam bearing replacement
I'll be doing h/c soon and I'll be pulling the motor to make it easier along with a few other upgrades I'll be doing at the same time. I'd also like to replace the cam bearings, mainly for piece of mind during the swap. Does anyone have instructions and pictures about replacing the cam bearings on ls1's? What exactly is involved?
Thanks.
Old 01-08-2006, 08:08 PM
wrencher
wrencher's Avatar
Removal of the engine is required. That is a precise installation that takes special tools & the know how to install them. That is generally a rebuild/overhaul operation.
Old 01-08-2006, 08:50 PM
My90Iroc's Avatar
I will be removing the engine. What special tools would I need? What is the process and the "know how" needed for this task?
Old 01-08-2006, 11:15 PM
LS1TECH.com Sponsor
WS6store.com's Avatar
You need a special Cam Bearing Remover/Installer Tool. Lisle Tools makes a kit, but if I remember correctly its around $200. Most will let the machine shop perform this task as they have the tool and have done many in the past. If you arent going to do it more than once, it really doesnt warrant getting the tool.
__________________
WS6Store.com | Sales@WS6store.com
F-Body Performance Parts | 1-877-232-9701
Old 01-09-2006, 09:11 AM
Mr Ed's Avatar
Do you know if it is possible to replace just the front bearing w/o pulling the motor? I was doing a cam swap this weekend (my first) and when I pulled out the old one I could see that the front bearing does not look good. I don’t know if the others are OK yet but I am borrowing am endoscope to check them out. If it’s only the front bearing I would like to avoid pulling the engine if at all possible.
Quick Reply: Cam bearing replacement
