MTI x1 vs. F13
Old 01-08-2006, 07:06 PM
1nastyss's Avatar
Default MTI x1 vs. F13
Trying to make my mind up between the two, looking for the one that pulls the hardest down low for the street, but still be a good track cam. Looking for plenty of comments. Thanx guys
Old 01-08-2006, 07:48 PM
pontiac's Avatar
I have the X1 and pulls hard up top. low is still good but you can tella diff the higher you go
Old 01-08-2006, 08:42 PM
sprydncamd ta's Avatar
i have an f-13 and it pulls hard low end from 2500-on and just keeps pulling harder
Old 01-08-2006, 09:03 PM
WILWAXU's Avatar
Even with over a 85lb weigh gain. My car picked up 10mph in the quarter with MTI X1 cam and Stage 2E heads.
Old 01-08-2006, 09:12 PM
Pro Mouse's Avatar
X1 Cam all the way ,with my A4 and 4000 Verter the X1 from mid range up Rocks! Daily driven
Old 01-09-2006, 03:12 PM
AINT SKEERED's Avatar
Look up the tq numbers on f13's , they all make good tq and not just hp. That will give you better avg numbers and that is what makes cars fast.
I just added Edelbrock longtubes and with my currrent setup, I made370 ft lbs at 2800 rpms , went up to 409.33 at 4700 and was still making 350 @ 6300rpms. Hp was over 400 from 5100 all the way to 6900 with a peak of 425 at 6300.
My cam is a f13 +4 on a 112lsa my heads are so mild its sick. my heads only flow 256@.500 -257@.600 and the exhaust is nice but with stock valve flow 219@.600 with no pipe. and traps 120 mph in street trim with 17 inch forgelines all the way around.
f13 gets my vote
