Comp Cams Pro Magnum Rockers 1.75
Old 01-17-2006, 02:32 PM
7 Second Club
Phil99vette's Avatar
Default Comp Cams Pro Magnum Rockers 1.75
Anyone use these rockers? They look pretty good, has anyone tried them?
Old 01-17-2006, 02:55 PM
SStrokerAce's Avatar
Just put them on a set of Dart heads.
I like them. You have to clearance the valve covers unless you have spacer plates like yours.
Bret
Old 01-18-2006, 06:33 AM
SAM98WS6's Avatar
I use them..they are working great!
Old 01-18-2006, 06:52 AM
vettenuts's Avatar
What happened to your Jesel's that you were setting up?
Old 01-18-2006, 07:13 AM
SideStep's Avatar
Interested in results also...
Old 01-18-2006, 05:45 PM
Viper's Avatar
Me too....
Old 01-18-2006, 05:57 PM
Firehawk441's Avatar
We use them on everything. Not just LS1's.
Old 01-18-2006, 06:02 PM
SlickVert's Avatar
How does the weight compared to stock?
Is the stock rocker a ture 1.7 ratio?
1.75 ratio will add about .015 more lift to a .600 lift cam over a stock 1.7 rocker
Old 01-18-2006, 06:14 PM
7 Second Club
My motor has Jesel's, its a clients car.
Phil
Old 01-18-2006, 06:45 PM
Viper's Avatar
For $485, they might be a good alternative over stock and for those who don't want to spend $1500 for Jesels ( with spacers ) no? My valve covers are already cleared from a previous experiment.
http://www.powerandperformancenews.c...ry_Code=pmRCKR
Old 01-18-2006, 07:07 PM
vettenuts's Avatar
Stainless should provide a problem free street rocker with minimal fear of fatigue, but I don't know what the rotary inertia is on these rockers. Haven't seen the numbers, but the Cranes are supposed to have less rotary inertia than the stock rockers with a better bearing system internally.
Old 01-18-2006, 07:09 PM
LS1 Tech Veteran
Steve Bryant's Avatar
I have them. Great rocker arms. Quality parts.
Steve
Old 01-18-2006, 07:25 PM
Randy WS6's Avatar
I have a set to, ready to install on my new aluminum 418cid,and they change the lift of the Crain Cam that im going to install ,with 1.7 r.a. 250/266-635/635-112+5 toComp Pro Mags 1.75 r.a. 250/266-650/650-112+5 right were I want it.
Old 01-18-2006, 07:40 PM
Most times the steel rockers like the Pro Mags are better in terms of mass over the valve (or rotary inertia) than a aluminum rocker.
FWIW I design the cams around these rockers, it's actually a better way to go.
Bret
Old 01-18-2006, 07:59 PM
z-ya's Avatar
I got a lot of flak when I put these in along with 3/8 pushrods and morel lifters.They
all told me the extra weight would kill me,it doesn't seem to be the case.
Old 01-18-2006, 08:28 PM
Viper's Avatar
"Most times the steel rockers like the Pro Mags are better in terms of mass over the valve (or rotary inertia) than a aluminum rocker."
Most? When is it not? Just trying to learn. I have a 227/231 575/579 custom EDC cam.
Old 01-18-2006, 09:07 PM
Well MOST TIMES the steel rockers have less mass over the valve!
Z-ya, you put the mass in the right spots, lifters and PR can have more mass and not hurt you at all.
Bret
Old 01-18-2006, 09:38 PM
gomer's Avatar
I'm installing a set of these on a customer's car next week. I read above where valve cover spacers are required. Who has installed these and what kind of mods did you have to do to the covers or pushrod holes?
Old 01-18-2006, 10:07 PM
Taspeed's Avatar
I have been wanting to use these on an ls1 for some time now, but I can say that from past expirience with them on LT1's and sbc's i've built that they are excellent rockers. Problem free for me.
Old 01-18-2006, 10:17 PM
What you want to clearance on the covers is the hemispherical protrusions that are below the coil pack mounting holes. That and the baffle inside the drivers side cover.
I also milled the walls that stick down into the heads on the passenger side cover thinner so there was more clearance there.
Bret
Quick Reply: Comp Cams Pro Magnum Rockers 1.75
