ET Head Selection
ET Head Selection
I am using a TSP magic stick 3 cam, and I plan on purchasing a set of ETP 215 heads. I would like to have between 11:1 and 11.5:1 compression. What are the best options to go with as far as which valve springs, combustion chamber size, etc.? Also i believe that they are 11* standard instead of the normal 15*, am I right? What pushrods, head bolts, and gaskets would I need with an MS3 and the ET 215 heads?
You'll need to upgrade to .650" springs, get 60cc chambers, and .045 gaskets. This will make 11:5:1 compression. The heads are 11*. Pushrod legnth will be around 8.100", but you will need to verify with a adjustable pushrod legnth checker to make sure. ARP head studs will be the best for clamping down th eheads. Cometic makes the .045" gasket.
I thought their springs were good to .675"? The upgrades i was to understand was for their 15 degree ported stock castings. Maybe im wrong.
Nate
Nate
Nate
