Polishing a cam
Polishing a cam
I have a cam with some rust on it. I know that pitting means it's a no go. So I want to polish it to see how extensive it is. What is the proper way to do it?
2000 grit, metal polish, both?
If WD-40 and a scotchbright pad can't get it off, I'd consider moving onto another cam, or sending it off to be re-ground. Any more aggressive of a material and you risk further damage to the lobe surface, and ultimately the posibility of what SStrokerAce was hinting.
