ISKY cam ?
ISKY cam ?
A friend of mine is getting a real good deal on this cam. He has all the Bolton’s, Lid, long tubes, catback. No LS6 intake. Would this cam be any good for his setup? What about a tune? Thanks
ISKY CAMS
grind no type rr-280/290 hydraulic roller application excellent mid-range performance. fair idle. 2500 stall. 3.70-4.00 axle ratio. up to 1.5:1 compr. up to 750 cfm carb. rpm range 2500-6800 valve lift int. ex. .530 .540 valve lash hot int. ex .000 .000 adv. duration 280° 290° .050 duration int. ex. 232° 242° lobe center 112°
ISKY CAMS
