Engine Swap
Old 02-03-2006, 12:53 PM
01T-TopToy's Avatar
Default Engine Swap
Ok, here goes. I am a mechanical newb, I can hold onto a wrench, but usually limit myself to starter / alt/ oil changes..
I am losing the motor in my 01 SS, I HAVE to change jobs on the 16th, its near 2 hours or more each day in traffic, so a knocking engine is prolly a bad thing.... so, I cannot afford to have a pro R&R it, so an old timer I work with is offering to help, Neither of us have ever pulled a LSx anything from an Fbody, I am being told it has to come out from the bottom, is this accurate ?
Is it insane to yank it with a cherry picker from the top ?
The guy in question has alot of experience w /old school stuff, so is there anything we NEED to know, or should we not even attempt it?
All thoughts are welcome
Old 02-03-2006, 04:03 PM
Build #1's Avatar
I will tell you it does NOT have to come out the bottom. Take your time and label everything your first time.
Old 02-03-2006, 04:50 PM
2K2WS6TA's Avatar
Label everything, and take pics, so you get the routing correct, if the search is working there is a thread about swapping engines, with tips and some pics.
Good luck with your swap
Old 02-03-2006, 05:07 PM
Moderator
davered00ss's Avatar
You can pull it from the top. Took me and a friend about 3 days to complete. With stops for drinking, horseshoes & vollyball.
