Should I protect exhaust ports/oil in transport and garage?
Hey everyone
Wasn't sure where to post this..
For those who didn't see my 'spark plug being a pain thread' I cross-threaded my #1 cylinder plug hole and am going with h/c package.
Question is:
I removed my exhaust, headers and all, and now I need to have my car towed to East Side Performance. Since the headers are off, and the oil dipstick is out, should I do anything to protect the engine/exhaust ports? It will be probably 2-3 weeks in the garage before I'll have the car towed for the swap. Will I be fine just leaving the ports open and dipstick out?
Thanks
Question is:
Thanks
I would put the dipstick back in and tie wrap it to the block. I would also go to a marine store and buy some storage spray which is to prevent outboard motor cylinders from rusting over winter storage. Spray in each exhaust port. They I would wipe down the exhaust gasket surface where the manifold goes with some alcohol or lacquer thinner. Finally, I would take some blue painters tape and cover the exhaust manifold area completely to keep out junk. This time of year, with all the salt and sand on the road, I would be concerned also.
Good luck.
Good luck.
I don't think so, but any marina or marine store will have it. All the outboard manufacturers make this stuff. Make sure it is for storage, Mercury sells an anti-corrosive spray that works real well, but it leaves a waxy substance behind and I'm not sure how easy it will come off as it is meant not to. Boat US or West Marine will also have it.
