New cam decision
Old 02-22-2006, 11:00 PM
white98terror's Avatar
Default New cam decision
I have a 98 Z with ported LS6 heads,comp cams 220/234 530./534. lift, long tubes,ORY,BBK manifold, 3000 stall, 1.8 ratio rockers,373's, and just about every goodie in the book. And i would like a little bit bigger cam that is still mildly streetable. Any advice would be great.
Old 02-23-2006, 01:37 AM
TARZAN's Avatar
Are you wanting a nitrous cam? Just wondering why your current duration has such a large split...
-Will
Old 02-23-2006, 12:28 PM
Default re:cam desicion
I am planning on putting a bottle in it but am going to run NA most of the time the comp cams cam that is in it was in it when i bought the car and was wanting something way more rad. Like the TRAK or G3's
Old 02-23-2006, 12:49 PM
redtail2426's Avatar
put at least 570 lift on it,those heads will be choked a bit with those low lift numbers.
Old 02-23-2006, 01:22 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
-Will
Must have been a smaller large split...he has 1.8 ratio.
Old 02-23-2006, 01:24 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are gonna change the cam go back to stock ratio on the rockers and just get the grind that is gonna match what you want on 1.7's.
