Lgm G1x5 Cam Or Mti G1
I currently have the MTI stage2e heads and stealthII cam. thinking of going bigger, but the heads are milled .03. How big of a cam can i go with? MTI said G1 wouldnt be a problem, so i assume the G1x5 cam shouldnt be either, but not 100% sure. How much more power can i expect over the stealthII cam? I will also need a TQ converter if i do this. thanks.
Originally Posted by orangeapeel
Is that the LG cam you are talking about? G5X1? Only way to find out for sure is to check PTV when installing the cam.
Hi,
I've got the AFR 205cc (milled to 59cc). Have talked several times about this cam, cause I want to put it in, with LG - they're down the street from me. They've told me there should not be a problem with PTV and I've got Cometic head gaskets which are .040.
Take care...
Take care...
Originally Posted by 93ChevExt5.7
Hi,
Take care...
Take care...
