Are there any .0010 short timing chains or tensioners available?
Old 03-06-2006, 12:44 PM
VTESPEED's Avatar
Default Are there any .0010 short timing chains or tensioners available?
Anyone know of any timing chains available kind of like small block chevys/fords etc that you can get one in 10 thousandths shorter to tension after the block has been main bore/honed?
Or are there any chain tensioners available..
Old 03-06-2006, 04:55 PM
10 Second Truck Club
67SS509's Avatar
Cloyes makes one. $300+ but it will never stretch.
Old 03-06-2006, 05:06 PM
gollum's Avatar
Good question. Contact our engine building sponsors.
HALLZ's Avatar
GM makes a chain dampener
Old 03-06-2006, 05:33 PM
gollum's Avatar
Whenever you line hone a block to make saddles strait with good bearing crush you have to shave the caps a few thousands" and then hone. This will make your timing chain looser than before especially if they over did it. This is why he needs a shorter timing kit to compensate.
You may be better off finding a good, used, cheap, block.
http://cgi.ebay.com/ebaymotors/NEW-G...spagenameZWDVW
