keep 317 heads or get ls6 heads for 6.0
Old 03-12-2006, 10:23 PM
1bad70+94camaro's Avatar
Default keep 317 heads or get ls6 heads for 6.0
should i keep and work the factory heads off my 6.0 or get ls6 heads.i have decided to go with 228 cam.remember engine is carbed.holley 750 vacuum secondary.
Old 03-13-2006, 09:19 AM
hals73rs's Avatar
Go with the head that puts compression where you want it. Both heads flow nice and make good power.
Old 03-13-2006, 09:46 PM
anybody else?i am hoping for 425 crank horses.can i get it with .030 6.0 with cam?
Old 03-14-2006, 12:07 AM
Richard@WCCH's Avatar
Is your 6.0l an LQ4 or LQ9? There's a compression ratio difference between the two. It would also help to know your specific application in order to make a proper recommendation. Tell us if it's a car or truck (or boat?) and things such as transmission/converter (if applicable), gear ratio and tire size. Will this engine be boosted or injected with N2O?
The cost difference with the LS6 vs the 6.0l head cores is around $300.00 per pair. That needs to be factored into your build budget.
Good luck,
Richard
Old 03-17-2006, 04:52 PM
GRFMotorsports's Avatar
Ill chime in with a question here as well.... I was originally going to use a set of 317 head on my 6.0L Im building with a domed piston for about 11 to 11.5 to 1 cr. Well I got a load of 241 and 243 heads in as well as a nice set of lq9 pistons and rods. So my question is assuming I am using an undecked block, factory GM head gaskets and unmilled 243 heads, how much would the cr ratio be with the smaller chamber instead of the 317 casting? Thanks in advance!
Old 03-17-2006, 04:57 PM
NemeSS's Avatar
u might have to re figure ur scr again but
317=72cc
241=67cc
243=65cc
hope this helps
Old 03-17-2006, 06:29 PM
ArcticZ28's Avatar
Well, do you want higher scr? Then go with the ls6's. If not, then stay with the 317's.
