How many passes can you get out of stock 01/02 L19 rod bolt?
In process of re-assembling stock shortblock, would like to re-use the stock L19 bolts if it is safe to do so. If it is safe, what is the spec? Thanks.
Because ARP's could possibly change the clamp force or throw the rod bearings out of round. Also a consideration is the difference in weight between stock and ARP's having an effect in balance.
I'm still not decided on what I'm going to do. I know L19's have proven to work very well, much better than the 98-00 bolts. I don't think there will be a problem using them, I'm just concerned with streching them again. If I can be assured the arp's weigh what stock does, I might just use those.
It won't change the balance of the rottating assembly enough to be a problem. I have never heard of someone hurting a rod bearing from more clamping force. Don't reuse a torque to yield bolt. I would go with a set of arp 2000 bolts.
