Checkin pv clearence ms3 and dart heads
Ok i have never done this before... but after reading the last post about the dart cnc ported heads i got scared and called tsp.. they said it cant hurt. Well i got soem clat and put it on the piston. Not sure how think i sohuld make it? it was a little under 1/8in somewhere in there. So i turned the car over and on the intake valve made a mark in the clay. did i make the clay to thick or do i not have enought pv clearenc? i dotn no what to do now thanks for the help guys
well dam it was close.... i am goin to have to call tsp again tomm. And have to try the clay again. if it didnt cut right threw to the piston it was close as hell.
You also need to be using an adjustable pushrod, rockers tighened down and 0 lash on the lifter......once you have a mark in the clay, you need to measure how much you have left between the bottom of the mark and the top of the piston using a dial caliper. You need .080" or so, just under 3/32".
I agree with predator, guits, and 1fast. There are a few threads about measure p/v clearance with dial indicator.
I did not use an adjustable pushrod, but next time I do it I think I will. Should make it easier on me.
well with the clay i cut right threw and saw the piston. so i sohuld still do the dial indecator? or i ahve 3 other options 1. send the heads back and get the valves sunk .040 thats as much as he can do. what will this do less compression? 2, look into gettin some etp heads they will clear if i am not mistaken. 3. smaller cam. I would like to get the most out of my H/c i can and i no a big cam liek the ms3 would do that but now it has became a pain in the ***
I have a question that has been bothering me with clearance checking. Does the fact that the lifter is not under oil pressure affect the valve movement? In other words, will a pumped down, no oil pressure lifter collapse and give an incorrectly smaller valve movement reading than what would be the case under normal running conditions.
I know how you feel I waited almost two months to get these heads. I just want to get it running.My heads were also milled .015. I don't know how much clearance you have but I did not have any. Maybe the torquer will work for you.
Yes, it matters very much. If youre using a 5# checker spring, and you torque the rocker down to 22 ft lbs, the lifter overpowers the checker spring and you get no lifter preload, which will considerable lower your p to v. If you used normal valvesprings, and you used a hydraulic lifter, the lifter cup and plunger will bottom out before it starts opening the valve. This will show more P to V than you will actually have when you run the motor.
The most correct way to test, is to use the checker spring, and install an adjustable pushrod and get the lifter preload down to 0 when you torque the rockers down. If you dont have an adjustable PR, you can always just hand tighten the rockers till theyre snug against the pushrod and the valve (youll likely see a .050 or more gap at the pedestal.
HTH
what is this cheaker spring? i used the springs that came in the head. i also used a stock pushrod. what should i be doin exactly is that why i am gettin a bad readin in the clay and its cuttin threw?
Originally Posted by GuitsBoy
A checker spring is a little low weight spring that you can easily compress with your hand. Its used for mocking up the head and taking measurements like this. If you were using your regular valve springs, usually this overestimates your P to V rather than underestimating it.
https://ls1tech.com/forums/showthrea...highlight=clay
you have hydralic lifter they pump up when the engine is on and there is oil pressure, if the engine is off and there is no oil pressure the lifters are not gonna be pumped up and you will have a reading that is incorrect, but when they pump up your pv clearanc is gonna be less then it is now so make sure ur using the right length pushrods also buddy and wat rocker are you using???
