5.3 and 5.7 LS heads stock valves sizes?
what is the stock valves sizes of each head above?
how do i know that the head i'm buying from the junkyard is a 5.3 LS head?
does it have certain casting number that i can identify the 5.3 head with it?
thanks for the info.
The 5.3 heads come with 1.89"/1.55" valves and the 5.7 heads come with 2.00"/1.55" valves. The 5.3 heads will have a casting number of 862 or 706. The 5.7 heads can have 806 (97-98 perimeter bolt), 241 or 853 (99-up LS1 heads), and 243 (LS6/LS2 heads).
You can improve the flow by increasing the valve size and doing some work to the bowl area along with a good valve job. If you would like, we will be glad to price doing our CNC porting to your set of heads.
thanks again Gunnar.
halla PREDATOR-Z (smile), you know i have to ask questions to get some answers.
last question (smile) : what compression with 0.015" milled 5.3 head and stock GM head gasket in a stock 346 short block?
will i be safe from the valves hitting the pistons with the 0.015" milled 5.3 head, stock GM head gasket and the TSP 233/239 cam in a stock 346 LS1 short block?
thanks.
thanks.
