ARP Main studs
If it has the stock GM bolts in it leave em there, they aren't really a problem area in those motors. You might get away with it but when you install studs into a block you are putting different forces on the block than what you would with bolts. It could slightly warp the bore. To properly do it you should have the block line bored to ensure it's 100% dead on.
