Cam question??
Old 04-02-2006, 06:59 PM
vetred's Avatar
Default Cam question??
I know this is probubly dumb but who makes the "torquer" cams?? and who has the best prices on new? Ill decide the "piticulars" valve size, ratios, springs & push rods rockers ect. ect. later as Im in the planning stages right now I know that I MUST be able to pass emissions and run on pump gass!,.......as long as we have pump gass!
Old 04-02-2006, 07:08 PM
ThirdGenLS1's Avatar
Well Texas-speed sponser here is who sells it and thats the only guys you can get it from. If you have to pass the sniffer for smog there is no way you wil pass with this cam.
Old 04-02-2006, 08:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yeah, the TQR v.2 will not pass smog. You want to stay in the 220-230 range as far as duration goes. You would be a good candidate for the 224/224 114 grind.
Old 04-02-2006, 09:25 PM
vetred's Avatar
Thank you, brothers,......S**t, well Im glad I found out now Instead of later! I dont know what Im going to do but I need this car for more than just the strip! I have a guy that will know if there is anyway to beat the sniffer with timing adjustments or additives! I allready know the answer I think!
