What cam with MTI Stage 2 Heads??
LS1TECH Sponsor
I have a G1 but bought these heads and may have some problems with PTV...
These are MTI Stage II Heads (1999 LS1 Castings),reworked in 2003 with larger Ferrea 2.08/1.60 valves, Ferrea titanium retainers, larger diameter Isky dual springs, and milled a total of 50 thousands to make the combustion chamber roughly 57cc's.
My G1 cam is 228/232 .588/.575 +4 at 115 lsa, also any guesses on pushrod length?
I owned this exact setup but with no milling. .050 is cutting alot. When I asked MTI if I could mill the heads they said NO! I will tell you the 115 lsa will be better than a 114 or more narrow lsa for P to V. Really you are not going to know until you test and measure it.
I used a 7.4 PR, and it was noisy. If you are not going to measure, just use 7.4s it should have a bit more preload and less noise...
