What all is needed for a strong 383 buildup?
Old 07-24-2006, 06:13 PM
Fibbado's Avatar
Default What all is needed for a strong 383 buildup?
I mean everything.. obviously the rotating assembly but what else would be needed for a very strong/bulletproof 383 out of an LS1.
What engine machining?
What valvetrain upgrades?
Engine girdle?
... looking to buildup a strong and extremely reliable 383.. even if components are slightly overkill.. I'd rather do it all at once and do it right.. i want to be able to rev high without fear and run nitrous without fear...
Any input appreciated
Old 03-01-2007, 08:06 PM
stage274's Avatar
go to www.dmperformance.org, I would never build an aluminum block with out the patented lsx engine main girdle, also see my project car link, I built a 383 just like yours, and I am expecting easy 800 ft lbs out of the set up.
Old 03-02-2007, 07:10 AM
slow trap's Avatar
it seems you are ready to spend some money so why not go ahead and build an aluminum 402 or iron 408 ? if you are wanting good internals like say lunati the shortblocks would not be all that much higher.then with any of the strokers you will need a decent head to help that big boy breathe.i would check with some of the sponsors and see how much a long block would be.
