Is the stock GM rocker arm stand necessary?...
Old 07-30-2006, 08:34 PM
Stroker2112's Avatar
Default Is the stock GM rocker arm stand necessary?...
Guys,
Are any rebuild guys out there keeping the stock GM rocker arm stands under the rocker studs? I've got ARP rocker studs and was just wondering if they are necessary....
Stroker2112
Old 07-30-2006, 08:56 PM
LS1FIRE's Avatar
Not sure what you talking about. do you mean the rocker pedestals?
sorry if im not understading ya correctly not sure what ya mean.
Old 07-30-2006, 09:29 PM
I think we're talking ablout the same thing. SCRoggin Dicky and Lingenfelter call it a Rocker Arm Stand....it goes between the head and the rocker stud, provides a base for the rocker arms..(it's one piece)...
Old 07-30-2006, 10:00 PM
dschmittie1's Avatar
well the rocker stand provides the pivot point I would think you need it still.
Old 07-31-2006, 07:49 AM
vettenuts's Avatar
Either the GM or a upgraded replacement is necessary. The LPE stand is very nice and will help stiffen a ported GM casting. You can't eliminate it if you are running stock rockers. Hope that answers your question as I am a bit confused also.
Old 07-31-2006, 08:13 AM
lt1formula2000's Avatar
as was said above if you keep the stock rockers then yes you need to keep it or get a better version. the rocker stand is what keeps the rocker aligned, without it the rocker could turn to the side and slide off the valve
Old 07-31-2006, 08:14 AM
GuitsBoy's Avatar
yes, very necessary for locating the rockers correctly.
