What could be wrong with the car now?? It won't start
Driving the car Wednesday night. Buddy and I were sitting in the car at a redlight talking, and then the car just shut off. Didn't make any noises or anything. It just shut off. Tried to start it back up, and it wouldn't start. You turn the key and it sounds like the belts and stuff are trying to move, but they don't. It only lasts for like a second. I've only had the car back for 3 weeks now. Is it an electrical problem? Is it losing power somewhere? A ground wire or something? We tried to jump it, and that didn't change anything? We got the car home and my buddy Derek came over Thursday night. He seemed to think the motor was locked to begin with. He got under the car and tried to turn the crank. Got a socket & torque wrench out, tried to turn the crank, and it didn't budge. Is that an indication the motor is locked? (and the car was in neutral) I don't have a clue, so maybe someone can offer some advice/help.
TIA
James
TIA
James
6600 rpm clutch dump of death Administrator
If the motor won't turn with a socket, you have larger issues. Pull the plugs and see if you see any issues, like impact to the plug. If you do, something is broken. Also pulling hte plugs will make it easier to tun over. But, it sounds like you may have brojken something internally. if you did, its got to come apart most likely. Good luck.
