New Injectors???
New Injectors???
I am installing a MS4 and PRC LS6 heads. My tuner thinks that I need 36Lb injectors for safety. I guess they have an MS3 running 105% injector usage at WOT and he is leaning WAY out. Do I NEED injecetors or will I be OK???
How often do you update your sig???
I would go with SVO 30's just to make sure you have enough fuel. Also, I don't see any fuel system mods.... I would also look into a racetronix fuel system to supply those SVO injectors with fuel.
Again, this is all what 'I' would do (and have done).
Good luck!
Good luck!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Good luck!
Good luck!
