oil pump spacer, RTV?
Doing a H/C swap, and I put a double roller timing chain on. I put the oil pump on, (o-ring seated) and I realized I forgot to put RTV sealant on the pump side of the spacer's oil passage. Should I move on, or take the pump back off and seal that side of the spacer, around that oil passage? Will it cause weepage/oil press problems if I don't?
