Bore and ring gap for 300 shot
The bore should be 3.905", if you measure the slug the clearance is typically buillt in. So for example if you told the piston company you had a 3.905" bore and max nitrous use, I'd guess your piston is 3.900" or there abouts at its measuring point.
Now as for the nitrous, your using 300hp on your third stage you say. What about the other two.
