Grounding connections
Guys,
Does anyone have a link, documentation, and/or diagrams referencing where all the grounding connections go on an LS1 engine?
This is the only thing holding me up on my 408 rebuild...can't wait to start it up.....
Stroker2112
iron 408ci, forged, TorquerV2, Patriot CNC'd 243 heads, Patriot Golds, true dual exhaust w/flowmasters, K&N Air, and every other free mod known to mankind
Stroker2112
A ground is a ground is a ground. Find something metal and ground the wires that need to be grounded. The back of the head is a good place for the wires that need to be grounded back there. You can also use the engine as a grounding point or find some bolts on the car nearby.
Theres One Ground That Goes In The Passengers Side Head, Two In The Drivers Side, One On The Drivers Side Of The Block Near The Motor Mount And One That Your Going To Have To Decided Where To Put To The 6.0 Block Near The Started Since The Hole That 5.7l Had For The Ground Is Not In The Same Place For A 6.0l Block
