cam question xxx
cam question xxx
i was recomended a cam from crane the numbers are:
@.004 284/290
@.050 222/228
lift-.551/.551
lsa 115
overlap 57
i was wondering if this is a good choice they call this cam tripple x and i was wondering if anyone knows how much lift and duration you can run on stcck heads with out running into piston to valve clearance. any help will be appriciated. thanks
@.004 284/290
@.050 222/228
lift-.551/.551
lsa 115
overlap 57
@.004 284/290
@.050 222/228
lift-.551/.551
lsa 115
overlap 57
@.004 284/290
@.050 222/228
lift-.551/.551
lsa 115
overlap 57
I believe you can get a Magic Stick, Trex, MS4, FM15, Maybe even the ASA cam. On a 64 cc head shouldnt have an issue, its when you start milling down is when issues start. Lilbuddy hit it on the head, what I run and what you have listed are base cams.
