Which heads to get for my setup??
thnx .. will fix the sig
from what i understand .. there are a few AFR 205cc's combustion volumes to choose from ... which one will suit my setup and will achive the most HP gains without compromising the engine's reliability on 95 octane pump gas??
Originally Posted by ringram
Cant read your sig either.
2.5" catback, Pacemaker 4-2-1 headers, Comp 918 Valve Springs, G5X1 camshaft, FAST 78mm intake manifold and throttle body, Rollmaster Double timing chain, 160* stat, Greddy Catch can, 4" cone filter, custom airbox, ASP underdrive pulley, NGK iridiumIX sparks, Taylor pro race wires, Pro 5.0 short shifter, 3.91 gears, SPEC Stage2 clutch, SPEC aluminium flywheel, B&M tranny cooler, custom HPT tune
Parts on the way (ordered):
Mahle 3.898 pistons + rings, CV axles, 3" driveshaft, Harrop diff cover, LSD
Parts on list (to be orderd):
Meziere EWP + t.stat, Heavy Duty Oil pump, Heads
hope this makes it clear
