pushrod length?
Old 10-03-2006, 02:31 PM
Cerebrex's Avatar
Default pushrod length?
Will the pushrods be stock length for the CNC LS6 heads and torquer II camshaft from TSP on normal GM head gaskets? I was unsure on this, and just wanted to clarify it would be the 7.4"
THANKS!
Old 10-03-2006, 08:17 PM
ISeeRed's Avatar
Do you know what the advertized base circle of that cam is? Standard LS1's are 19.7mm (That is a radius number--Double it if you measure it) If the difference is .6mm or greater you would want to adjust pushrod length.
