Breaking up under full Throttle
Old 10-06-2006, 05:34 PM
CLRides's Avatar
Default Breaking up under full Throttle
I am getting some breaking up under full throttle. Part throttle is fine and when the engine is below 150 degrees. So it runs fine first thing in the morning.
Mod's SPL Long tube heades, SPL 1.85 rockers, 3000 Vigilate Stall, MTI TB, MTI Tune, K&N Filter Kit, and LS6 MAF.
I have checked several things (Changed plugs/wires, Fuel pressure fine, No Codes, Re-installed stock MAF, TB to try it and it still breaks up) Anything I can change with HP on Tune to help.
Old 10-06-2006, 05:46 PM
Slo_240sx's Avatar
In the mourning youre still in closed loop and fuel is being enriched. Sounds like you need to recheck your tune.Your fuel map may be a bit off.
Old 10-06-2006, 06:05 PM
gun5l1ng3r's Avatar
I would also make sure you aren't having problems with your 1.85 rockers...
Old 10-06-2006, 07:24 PM
MNR-0's Avatar
I had similar problems. Turned out to be a broken valve spring
Old 10-07-2006, 04:00 PM
CLRides's Avatar
Thanks
