No oil pressure until you rev truck???
Old 10-07-2006, 03:54 PM
Extremedsm's Avatar
Default No oil pressure until you rev truck???
Ok, I have a completly rebuilt motor in my escalade. New ported oil pump from Lingenfelter. There is no oil pressure until you rev the truck up. Once it has oil pressure and you drive it around for awhile and shut it off for a couple minutes and start it back up, it has oil pressure. If you leave it for a couple hours, you have to rev it up again. Any ideas?????
Old 10-07-2006, 04:45 PM
seawolf18's Avatar
Confirm your oil pressure with a mechincal guage. The oil senser might be scewed up. If you get the same readings as your factory guage, then you might have pinched the o-ring when you installed the pump. Pretty common i hear.
Old 10-08-2006, 02:31 AM
ninobrn99's Avatar
check oring. pretty common.
Old 10-08-2006, 02:36 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yeah, that thing is prolly pinched or dislodged.
Quick Reply: No oil pressure until you rev truck???
