What decides safe redline?
Old 10-07-2006, 10:07 PM
99blancoSS's Avatar
Default What decides safe redline?
What decides your safe redline without leaving anything on the table.
If you have a forged 347, ARP bolts and the GM hi perf lifters from SDPC and a 232/240 cam where is the redline? If the lifters arent an issue whats the weak link now. (Besides the cam and where it falls off)
Just the rockers? Should you be stepping up to guide plates and such or is having Harland Sharp through Nasty just as good?
At a point where it doesnt make sense to leave something to chance.
Old 10-07-2006, 10:25 PM
ninobrn99's Avatar
tough to say. if the motor is built for those rpms, id also assume it would be where the cam fell off or where the tranny gives out.
Old 10-08-2006, 11:11 AM
JEB99TA's Avatar
... sounds about right. After mine was forged and built, I've rev'd to 7,000 rpm's several times and the engine hasn't sustained any noticeable damage. With that cam and motor you describe, my personal opinion is that your shift points should generally be no higher than 6,800 rpm's, but, ideally between 6,100 - 6,350 ... just my opinion ... a lot of other smarter folks here will prob differ in opinion.
Old 10-08-2006, 11:48 AM
99blancoSS's Avatar
Well the folks at TR said I should be shifting the 224 I had at 6400 rpms. We figured a shift point at around 6800 when they spec'ed out the cam for my weight and gearing. Safe redline with comp replacements was around 7100-7300 he figured but with the new hi perf lifters that should increase. Of course it doesnt make sense of the power falls off the table but its good to know where your limits are.
Old 10-08-2006, 12:38 PM
ninobrn99's Avatar
id set the limits to where the power falls off. there no reason to keep going after that IMO. most set their shift points 2-300 rpms over where peak is.
Old 10-08-2006, 02:03 PM
JEB99TA's Avatar
That's pretty much the main idea I was focusing on. I would NEVER go over 7,000 rpm's on an LS1 motor ... but that's me. I still say up to 6,800 is safe on your motor, but, it would be pointless with your current cam.
Old 10-08-2006, 03:32 PM
N4cer's Avatar
If you look at my dyno graph in my sig, my 224 cam was still pulling at 6600 where the rev limiter is set. And it's only set there because I have close PTV clearance issues. If the clearance was there, I'd have it set at 6800 at least. Plenty of guys spin a stock LS1 to 7k.
Old 10-08-2006, 09:29 PM
JEB99TA's Avatar
Last time I spun my old motor to 7k, my motor smoked and did all kinds of weird **** afterwards. Oh well, got it forged and rebuilt, so, I'll spin it up to 7k without worries now. Don't want to push engine life, so, I'll keep it there at or below 7k ... just my personal take.
Old 10-08-2006, 10:47 PM
WhiteStripes's Avatar
If you want to get a really high revving motor call Katech, they make a block that rev's to 9k I believe.
Old 10-09-2006, 03:44 PM
cam
cam's Avatar
Thats exactly what I did. I spoke with Jason about RPM limitations and his advice was no higher than 6400 RPM with stock valves regardless of springs or ti retainers. He said the stock valves were too heavy for anything higher even if others do it and it works he does not recomend it. Stock bottom end he said was pretty good and not really an issue past 7000rpm N/A so long as its in good order and if 99 or older has new rod bolts.
Good enough for me.
