identifying head milling
Old 10-08-2006, 08:24 PM
iamsickofitall's Avatar
Default identifying head milling
is there a dead giveaway to knowing whether or not a set of heads were milled such as tooling marks or other visual markings?
i have 317 heads to lower my compression and i don't want to have to CC them with a buret if there is some easy way to visually identify they have or haven't been milled.
Old 10-09-2006, 01:33 PM
anyone?
Old 10-09-2006, 01:35 PM
chpmnsws6's Avatar
Not really, if you want to be sure, have them checked
Old 10-12-2006, 12:06 AM
rhubar's Avatar
most up-to-date shops can duplicate the cbn finish on a set of untouched gm heads, so ur best bet to to get them mic'd
Old 10-12-2006, 12:25 AM
ShevrolayZ28's Avatar
My heads had the amount of milling stamped onto the non-contact part of the gasket surface.
Old 10-12-2006, 05:50 AM
PREDATOR-Z's Avatar
Measure deck height and substract from original.
You can PM Tony Mamo or Gunnar, they have the original measurements.
