timing cover hitting oil pump..HELP!
Old 10-27-2006, 02:41 PM
michael402z06's Avatar
Default timing cover hitting oil pump..HELP!
my timing cover is hitting my oil pump and up by the cam sensor. i blackened everything with a sharpie to see where everything was hitting but my question is after i grind some to make it clear is the timing chain going to clear the cam sensor?? i would just get a single roller but i have it installed already and i need to have it all put together this weekend and i won't be able to have one here by then without having to pay 50 dollars for shipping. if i knew that i had to deal with this i would have just got a single roller.
thanks for the help
Old 10-27-2006, 04:12 PM
00454sscamaro's Avatar
phillips screw instead of bolts, works great, no grinding... - link-https://ls1tech.com/forums/showthread.php?t=592897
Old 10-27-2006, 04:21 PM
so the mounting bolts will clear it is the other bolts that need to be changed out with screws?
Old 10-31-2006, 08:50 AM
yeah, all i changed with mine was the oil pump cover bolts and my timing cover went on easy and didnt hit anything. your hitting on the mounting bolts? or were you told they would hit etc?
Old 10-31-2006, 06:36 PM
ArcticZ28's Avatar
Sounds like the oil pump is shimmed too much. I have a rollmaster double roller, used the supplied shims and have no issues.
Old 11-01-2006, 08:06 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Same here
Keith
Old 11-01-2006, 01:05 PM
the main problem i had was up by the cam sensor there is an extra piece of metal that comes through the back for the extra bolt for the ls2 cover to hold the cam sensor bracket on so i just grinded it off and welded the back of the hole and shortened the screw.
