Oil Pressure sensor went bad again!!!
Old 10-30-2006, 12:51 PM
1stz06's Avatar
Default Oil Pressure sensor went bad again!!!
Anyone have problems with this. My friend purchased a used C5 with procharger already installed. Soon after he received the car the oil pressure sensor stopped reading. We replaced it with a new one from GM 2 weekends ago. This morning he fires her up and NO OIL PRESSURE reading........again!!
Anyone have any idea what the cause of this could be????
Thanks in advance,
J.R.
Old 10-30-2006, 02:09 PM
bczee's Avatar
Are you sure that the Sensor is bad and your not really getting Zero or Low pressure ?.. maybe put a manual Oil Pressure gauge on the port above the oil filter to get a reading.
Old 10-30-2006, 02:13 PM
ArcticZ28's Avatar
I'd check the wiring for shorts that could be causing it to take a dive.
Old 10-30-2006, 03:04 PM
1stz06's Avatar
Actually, he is telling me that it is reading like 80-100 PSI.........that is way wrong for a stock LS1 oil pump. I was reading around 35-45 last week. From what I have learned on the corvetteforum, this is very common. They are just pieces of sheet and go bad very often.???
Old 10-30-2006, 03:05 PM
ArcticZ28's Avatar
They don't go bad in two weeks.
