VHP / Crane Accelerated Roller Rockers 1.7 or 1.8
Old 11-01-2006, 07:32 AM
SideStep's Avatar
Default VHP / Crane Accelerated Roller Rockers 1.7 or 1.8
My Corvette has become a full-time DD so I swapped out my 226/230 (XE-R) cam for a factory ZO6 cam (2002)... I noticed my rockers (also factory) are showing some "slop" and I was looking at the Crane Accelerated Roller Rockers as a replacement... I searched and found some bad press floating around about the 1.8s floating-out over 5500rpms...
Any advice/input would be appreciated, my AFRs have the base dual springs... (and yes I already searched, looking for more info...)
Old 11-01-2006, 11:56 AM
vettenuts's Avatar
The issue above 5,500 I believe was spring surge on the Crane 832's. I had that issue. This spring, I swapped heads and used the Dart installed PSI beehive valve springs. Curve is as smooth as a babies, well you know
These rockers, in my opinion, are excellent. However, I have been told that the Patriot springs don't like them for some reason. Not sure why, I am only repeating what one builder told me. I would consider a spring swap with the rockers, or at least be prepared to shim your current springs. You could try it and see how they work, then go from there. The rockers themselves are extremely nice. Also, they require shorter pushrods than stock, but the AFR heads require longer than stock heads so you will need the AFR kit if you go this route. These are the Crane 1.7's that I installed on my Dart heads, I still have the 1.8's that I may put back in later.
Old 11-01-2006, 12:00 PM
SSpdDmon's Avatar
Originally Posted by vettenuts
I hate you!!! Is it wrong to have cowl envy??? My damn arms look like I got in a fight with Freddy every time I work on the back of my motor.
Old 11-01-2006, 12:17 PM
SideStep's Avatar
Thanks for the reply... I just got off the phone with VHP, absolute F'ing waste of time...
Old 11-01-2006, 12:46 PM
YankeeVert.'s Avatar
[QUOTE=SideStep]My Corvette has become a full-time DD so I swapped out my 226/230 (XE-R) cam for a factory ZO6 cam (2002)... I noticed my rockers (also factory) are showing some "slop" and I was looking at the Crane Accelerated Roller Rockers as a replacement... I searched and found some bad press floating around about the 1.8s floating-out over 5500rpms...
[/QUOT
You could use the GT2-3 cam (207/220 .573/.578/118.5). Almost the same cam with a higher lift. Then you would not need the rockers.
Old 11-01-2006, 12:56 PM
SideStep's Avatar
I already have the ZO6 cam installed and I need to replace my rockers... That is all this is about... The Accelerated Lift rockers lift at a higher rate for the beginning and ending of the lobe ramp compared to the top of the lobe...
Old 11-01-2006, 01:33 PM
vettenuts's Avatar
David Vizard just wrote an article on Popular Hotrodding that discusses off the seat acceleration using the rocker. In general, he thinks this is a great idea.
Old 11-01-2006, 03:43 PM
vettenuts's Avatar
I have to admit, I don't know how you guys work on the f-bodies the way the motor is tucked in there
Old 11-01-2006, 10:01 PM
mrr23's Avatar
i run the 1.8 accelerated lift rockers on the wife's car with no floating issues above 5500 rpms with the stock cam and the vinci 062 cam. either way, go with the 1.8 rockers.
Old 11-01-2006, 10:30 PM
pewter99ls1's Avatar
mrr23
What springs were you using with the crane 1.8 and stock cam? Dual or single? I have a stock 99 ls1 cam and all this talk about surging is getting me confused. I thought crane specified the dual springs because of "harmonic problems" in the upper rpm range. Since I have a stock cam and won't see above 6000 rpm, would some comp 918's work? Thanks for the reply. Sorry to hijack thread.
Old 11-01-2006, 10:32 PM
1999 SS's Avatar
what do a set of these vincci rocker arms cost?
Old 11-01-2006, 11:05 PM
JRracing's Avatar
Lots of patients and small hands help!
Old 11-02-2006, 05:04 AM
vettenuts's Avatar
Vinci has them on their web site for $669 I believe. This includes all the parts including hardened pushrods (they are shorter than stock, 7.250").
Old 11-02-2006, 05:05 AM
vettenuts's Avatar
Yes, I know someone running the Crane 1.8's with an aggressive Comp cam and Comp 918's in a Z06, no issues at all up to some very high RPM.
Note on the harmonics, Crane has introduced a new valve spring (833) to eliminate harmonic issues up to over 6,800 RPM. All valve springs have harmonics, it is unfortunately part of any spring design. The key thing is to minimize the harmonic response at any given frequency (RPM), which is how a beehive spring works, or to alter the spring assembly characteristics to minimize the harmonic response and/or push the harmonic response to an RPM higher than the motor will run.
Old 11-02-2006, 05:51 AM
SideStep's Avatar
I read through the installation instructions...
Is that the process you used for installation? Got any advice? I still cannot figure out if my low lift (.551/.541) ZO6 cam is going have this "harmonic" issue and the person I spoke with at VHP was not exactly reassuring...
Old 11-02-2006, 06:45 AM
McLeod's Avatar
I have the Crane 1.7's for sale if you are interesred. I bought them and didn't use them. I'm in Ashburn,VA.
Old 11-02-2006, 08:42 AM
mhoglund's Avatar
I'm also using the 1.8's. With the 832's harmonics came into play in the upper rpm range. I switched to the VHP 833's and have had no problems. If you do use the 1.8's, make sure you follow the install process thats on the Vinci website.
Old 11-02-2006, 10:06 AM
What rpm range did you start to experience the "harmonics" with the 832's? Was it something you could feel or something that you could see on a dyno sheet.
I really think with my stock cam the 918's may be what I go with.
Thanks for the replies.
Old 11-02-2006, 11:33 AM
vettenuts's Avatar
I couldn't feel it, it was on the dyno sheet. The 833's or Comp 918's will circumvent this issue. Not sure on the AFR springs though.
Old 11-02-2006, 12:10 PM
mrr23's Avatar
mrr23
ran the 832 springs. did the rockers and springs at the same time.
Quick Reply: VHP / Crane Accelerated Roller Rockers 1.7 or 1.8
