what h/c for the 4.8
Old 11-08-2006, 03:22 AM
viper2fast's Avatar
Default what h/c for the 4.8
i have a ls1 cnc ported heads and a cam228/230 .571/.573 112
can i swap them to my 4.8 truck or this cam
''XFI'' 260 Hydraulic Roller Cams
GM C/K Trucks 99-06 4.8/5.3L
Lift: .513''/.520''
Duration @ .050'':206°/212°
RPM Range: 800-5800
Lobe Separation: 115
Old 11-08-2006, 10:20 AM
SOMSS's Avatar
All the current production LSx engines have compatible heads/cams etc.
Old 11-14-2006, 06:07 PM
viper2fast's Avatar
what is better the 4.8 truck heads and ls6 cam or ls1 heads and cam228/230 .571/.573 112 any one can help
Old 11-14-2006, 07:45 PM
Cop Car's Avatar
the second cam you put down up there is pretty much close to a stock LS1s camshaft.
only heads that are excluded from your list would be LS7 and L92 heads. ported LS6 heads are probably all you need. personaly id go with a bigger cam, unless you have to deal with a daily driver.. but even then id run a bigger one..
