camshaft retainer plate gasket
I tore down the car last night to put the new cam and valve springs in and ran across a little problem. Evidently there is an O-ring seal on the back side of the retainer plate and I didn't buy a new one, didn't know about it, so exactly what is it's purpose and do I need that seal? The old one doesn't look bad so I was thinking about putting a really small bead of RTV across it just to be safe. Any thoughts on this?
It is attached to the plate. Check for cuts or other abnormalities. If none re-use, if there are questionable things I would replace the plate. Don't use RTV. This plate blocks off the main oil gallery so this seal is too important to save a couple of bucks on. If it looks bad, replace the cam plate.
