Ls1 and Edelbrock2215 cam question
Old 11-16-2006, 06:27 AM
chris-m's Avatar
Default Ls1 and Edelbrock2215 cam question
anyone have any thoughts as to what valve springs /retainers i should use on this cam please? Its only a mild cam by all accounts, and will be used with std heads. (engine is a 2001 stock ls1.)
advertised lift on that cam @ valve is 0.510" inlet and exhaust, cam duration at .050" lift is 220deg intake and 220deg ex.
used with a manual 5 speed box in a rwd track car (lightweight car), run to a safe max rpm rather than needing to be thrashed to the redline continually.
I've got some Comp Cams Hi-Tech 7.400" Pushrods in mind also (Part number: 7955-16)
Would the standard retainers do the job, or do i need uprated steel ones? (titanium would be nice but not really in the budget.) A suitable valve spring would also be handy to know?
thanks
Old 11-17-2006, 04:08 AM
chris-m's Avatar
anyone?
just need suggestions at to suitable valve springs (918s?) and if std steel retainers will work on this mild cam, or if uprated retainers required? i will be swapping the pushrods to uprated ones. rod bolts are also ARP type.
thanks
Old 11-17-2006, 05:40 AM
PREDATOR-Z's Avatar
918's and stock retainers more than enough
Old 11-17-2006, 10:50 AM
chris-m's Avatar
cheers
