intake ??s 4.8 vs 6.0 intake
Old 11-20-2006, 04:28 PM
Tootall's Avatar
Default intake ??s 4.8 vs 6.0 intake
I'm swapping the complete 4.8 out.
I've already asked around, I know that the 4.8 intake will swap over and bolt up.
Are the runners bigger,
TB,
injectors,
sensors? Are they all the same size.
This is a DD (daily driver) setup, I'm not looking for a LS6 intake or a LS1.
I've been offered a complete 6.0 intake for $75. Is it worth it.
Old 11-21-2006, 06:42 AM
v8bug's Avatar
I believe all truck intakes are the same only difference is the injector size.
Old 11-21-2006, 02:46 PM
5.3LJimmy's Avatar
Yes all the truck intakes, sensors, and throttle bodies are the same. And I'm pretty sure they all run the same injectors w/ the exception of the '99 model trucks.
Old 11-27-2006, 03:25 PM
bluecamaroz28's Avatar
I am wondering too.
What would it be like with LS1 5.7 instead of 6.0L in place of that 4.8L?
Old 11-27-2006, 03:29 PM
Tootall's Avatar
the LS1 5.7 intake manifold is more for top end, and the truck is more for low end power.
Will the 5.7 fit on your current truck motor? Yes, buy you have to mod your truck water pump, or just use all the 5.7 front accessories.
Quick Reply: intake ??s 4.8 vs 6.0 intake
