afr 205 heads with tr 224 cam??
Old 11-26-2006, 08:10 PM
vader99's Avatar
Default afr 205 heads with tr 224 cam??
I have been doing some searching on here and there is a lot of good info.
I would like some thoughts or any advice on the combo I was thinking of running.
I have a tr 224 224 112 +4 cam ready to go in and was wondering how a set of AFR 205 cc heads milled to 59 cc would work?
Would there be any P to V clearance issues? Should I run a stock gm gasket or something like a cometic?
thanks for any advice....
Old 11-27-2006, 09:39 AM
Ragtop 99's Avatar
With the higher compression of the 59cc head, I would consider retarding the cam by 2* when installing it for better overall performance.
Quick Reply: afr 205 heads with tr 224 cam??
