Why valve reliefs are so commond on built 347's?
All,
I'm looking to replace my LS1 short block due to the fact that my lifters/cam munched on eachother. My question is, why is it that the majority of the built 347 blocks out there have some sort of valve reliefs, i.e. -2cc, -4cc etc? I'm assuming this is due to folks want to add power adders, is this a correct assumption? Any input is appreciated as I'd rather go to the stock flat tops instead of wondering about the affect of this on my H/C daily driver.
TIA,
TIA,
Originally Posted by DONAIMIAN
The only reason for a valve relief is so when running a big cam, you wont have issues withthe valves hitting the pistons.
Kleeborp the Moderator™
Originally Posted by PewterC5-2000
I understand that but it just surprises me that the plain ole flat tops aren't as commonly available (in built blocks) as I would of expected.
the reliefs won't drop compression much.for each cc it is only around a tenth of a point.you could either run a set of thinner gaskets or shave your heads some to gain back your compression.
