ARP head bolts
ARP head bolts
are the head bolts(not studs) re-usable?
what is the advantage to going with studs over bolts? Are the Arp headbolts better than stock, or just good because they are re-usable?
Thanks
Louie
Thanks
Louie
There was just a thread about this yesterday.
https://ls1tech.com/forums/generation-iii-internal-engine/617672-arp-head-stud-kit-head-bolt-kit.html
https://ls1tech.com/forums/showthread.php?t=617672
thanks for the link!
Louie
Yes they are reusable. I have the head bolts because i dont plan on taking the heads on and off all the time. The studs provide a better torquing and make it easyer to put heads on and off. If you are planning FI or high compression go with the studs but the bolt will work fine for the normal guy. They are both reusable.
