Pending head upgrade install "lifter & rockers"
Old 12-13-2006, 08:58 AM
blazeone's Avatar
Default Pending head upgrade install "lifter & rockers"
My 2002 LS1 has 19,000 miles on it. It currently has an MTI X1 cam with stock heads w/918's and hardened push rods.
I'll be adding TSP 5.3L st2.5 heads soon. Should I use new lifters? maybe Comp OEM style. Also what about the rockers. Upgrade to the Cadi racing rockers?
Old 12-13-2006, 12:02 PM
PREDATOR-Z's Avatar
Not not necessary
If you haven't bought the heads yet, you are better of getting the headds with maximum 2.02 valves, that way you can mill a little and get more ptv.
Old 12-13-2006, 12:27 PM
blazeone's Avatar
Originally Posted by PREDATOR-Z
Not not necessary
I was planning on using a .040 gasket for around 11:1. With that said would the 2.04 valves be better.
